6-Gang getriebe W8
Diskutiere 6-Gang getriebe W8 im B5 Motoren Forum im Bereich Passat B5 (Typ 3B / 3BG); Sorry I’m writing this in English, I write better English than German, you can reply in German. In about a year I want to buy me a Passat...
  • 6-Gang getriebe W8 Beitrag #1
Goldberg
In about a year I want to buy me a Passat Variant W8 with a manual six-speed transmission. The 275ps are great but I want something different. Looking for an answer to gain me more power I found two options:
1. An Audi S4 2.7 biturbo with an AWE Tuning RSK04 turbo upgrade kit conversion.
2. Built a supercharger too and get it up to 400ps.
I already had contact with a shop here in the Netherlands. They told me it would take them about 2 months to built a supercharger kit for the W8 (costs about 4000-8000 euro, depending on the amount of horsepower gained). Searching the internet I could not find any specifications on the manual six-speed transmission that sits in the W8.
Could you guys help me with the model number/type number of this transmission and if it will put up to a power increase of 125ps??
  • 6-Gang getriebe W8 Beitrag #2
KaJu
KaJu
Emsland
Hello
The W8-Engine has temperature Problems.
No Tuner will build a kompressor for this Engine.
If you wont more Power, take the 2.7 bi-turbo.
Greetings
KaJu
  • 6-Gang getriebe W8 Beitrag #3
Goldberg
Hmm, I will contact http://www.vr6specialist.nl/ (the company I had contact with) about this. The told me it would take about 2 months to build a superchargerkit for the W8.
Could you tell me what the heat problem is? (watertemp, oiltemp, general cooling?)
  • 6-Gang getriebe W8 Beitrag #4
Alex
Alex
Hannover
Take the 2.7BiT
450 PS and front wheel drive :respekt:
  • 6-Gang getriebe W8 Beitrag #5
Goldberg
My biggest concern with the 2.7 Biturbo is the use/handling of everyday driving. I know a supercharged engine "feels like" a normal engine. How is this with a Biturbo?
Must say that the pictures above look awesome. The 2.7BT is also a lot lighter than the W8.
  • 6-Gang getriebe W8 Beitrag #6
KaJu
KaJu
Emsland
Hello
I can't tell you, because i dont know.
I only here it. Ther where many Engine Damages.
MfG
KaJu
  • 6-Gang getriebe W8 Beitrag #7
Hawk
Hawk
A-4800 Attnang
general cooling is the problem. the engine itself is geting too hot inside. because of the W arrangement the engine is very small compared to other 8 cylinder engines, but the heat cant get out. this is why VW has limited it to 275 hp ... it could have more, but you can get serius engine damage when you install a supercharger.
go for the 2.7 T :top:
  • 6-Gang getriebe W8 Beitrag #8
LessIsMore
hat der rote passat oben ne homepage?
würd da gern mehr drüber lesen
  • 6-Gang getriebe W8 Beitrag #10
Goldberg
Then the 2.7 T will be it. It will make my search a lot easier. It will be a Variant 2.8 4motion with a sunroof (love the solar-sunroof).
Thanks for the info :top:
  • 6-Gang getriebe W8 Beitrag #12
Goldberg
Hawk schrieb:
dont forget to post pictures when its done. :D
I won't forget, it will take a while, first I have to get the money together and find me a good car.
6-Gang getriebe W8
6-Gang getriebe W8 - Ähnliche Themen
passat b8 break lights always on: Good morning, I could use some help from your side. I have a Passat B8, 2018, DSG, 2.0 TDI. Since September I have problems with the car: the...
Engine Smokes and Stutters at 36-56°C when idle, Runs Smooth without Coolant Sensor - Need Help!: Hi everyone I’m having an issue with my 2001 VW Passat B5.5 (96 kW TDI). When the coolant temperature is between 36°C and 56°C, the engine smokes...
What Are the Benefits of Using Truck Starter Motor?: When it comes to starting a truck, the starter motor plays a crucial role in ensuring that the engine fires up smoothly. The truck starter motor...
New U MedSpa Your Trusted Haven for Botox Near Me: New U Med Spa, the go-to destination for Botox near me conveniently located in your area. Our seasoned professionals blend skill and artistry to...
Do You Know When To Change Tires?: When a car is on the road, the only thing in contact with the ground is the tire. The quality of the car tires directly determines the driving...
