Do You Know When To Change Tires?
Diskutiere Do You Know When To Change Tires? im B8 Innenraum Forum im Bereich Passat B8 (Typ 3G2 / 3G5); When a car is on the road, the only thing in contact with the ground is the tire. The quality of the car tires directly determines the driving...
chinagrtyre0
chinagrtyre0
Punkte Reaktionen
When a car is on the road, the only thing in contact with the ground is the tire. The quality of the car tires directly determines the driving control of the vehicle. If a car encounters a car tire on the road, it is very unfortunate for the car owner, so we should know when we change the tire.
1: tire thickness
Comparing a new car with an old car, car owners will find that the tires of the new car have a high degree of foaming, are brighter, have a deeper pattern, and have a better gloss, and the new tires are harder. The car has a flat tire, so the signal is a sparse tire tread, and the thickness of the tire pattern is less than 1.6 mm. In this case, the car will easily puncture. Every day, waiting for words to see hidden ruins in the tire seam, is not considered harmless, remember to use a clean stone hook to clean and reduce tire wear. The tread thickness of a normal tire must be greater than 1.6mm. If it is located in the south, the car often drives on the slippery ground due to the long rainy season. Therefore, it is best for southern car tires to ensure that the tread thickness is greater than 3.2mm. Old cars, old cars often have flat tires because they are too thin, so pay special attention to the thickness of the tires.
2: tire blowout
The car wheel trade fair shows that tire bulge is mostly caused by accidental strong impact during use, resulting in severe squeeze and deformation of tires. Once the steel cord on the side of the tire breaks, the air inside the tire will push up from the fault to form a bulge. Accidental collisions are the main cause of tire blowouts.
3: tire sidewall crack
According to China Auto Wheel Expo, we often see small cracks on the side of tires. If this happens, it may mean that the tire is flat, which will make the tire pressure unstable, leading to the risk of a flat tire. This situation may not be a problem in the short term, but it is recommended that car owners always observe the tires. If the cracks continue to expand, it is recommended to replace them directly, especially tires that are more than 5 years old.
4: abnormal vehicle vibration when driving
When the car starts to shake abnormally at high speeds, the owner must be very careful because this may be a tire problem. Of course, it may also be a problem with the engine and transmission. In this case, it is best for car owners to pull over as soon as possible for investigation.
Do You Know When To Change Tires? - Ähnliche Themen
What Does the Fuel Filter do?: Fuel filters keep particles, water, and impurities out of the fuel and protect the delicate components of the fuel system from wear and tear and...
Ceramic Brakes Pads And Semi-Metallic Brake Pads: If your car is screeching at you every time you pull up to a stoplight or a brake pad warning light is sending you a signal, you can be sure that...
How to Wash Your Vehicle Air Conditioners: You may hear the term "air conditioning system flush" when replacing dc air conditioning parts on your vehicle, either as a general industry...
Why Need To Be Replaced In Time?: 1. Check the engine light The bright orange "Check Engine" indicator light is one of the earliest signs you will notice that the oxygen sensor is...
What is the Concept of Employment Law?: Employment law is the collection of laws and rules that regulate relationships between employers and employees. If you are Looking help for online...
