sichering
Diskutiere sichering im B5 Elektrik & Elektronik Forum im Bereich Passat B5 (Typ 3B / 3BG); Hi, Sorry for my writing in English. I understand German, I just can't write it... :roll: I’ve been having some electrical problems...
  • sichering Beitrag #1
ALFIrE
I’ve been having some electrical problems (alarm and central locking system). I already checked out the comfort control module under the seat, but is is fine.
I’ve been looking at the fuses, and found out that it is fuse nr 14 (little 10A) that’s causing all my worries. This seems to be controlling the power windows and remote locking control.
Does anyone know what else it should control. Does somebody have the electrical layout concerning this nr 14?
Thanks in advance!
  • sichering
  • sichering Beitrag #2
W
wolve
Karlsruhe, Baden
Hi Alfie!
Please try to descripe your electrical problem a bit closer, especially how it occurs...
Greetz,
Klaus
  • sichering Beitrag #3
ALFIrE
Hi wolve!
Well:
alarm goes of without obvious reason
doors sometimes lock unwanted
I think it might be in the door lock mechanism as described here:
http://www.taligentx.com/passat/mainten ... mechanism/
BUT
I don't have any problems with the interior lights
I don't have the "door open" sign
I'm confused...
I'm willing to get a look at that door loch mechanism, but it is a lot of work and there's na garantuee the problem is reaaly there...
so, thanks in advance for any help!
PS: for my previous car I had all that data on a CD-rom, but not for the passat. and there is no VAG-Com in the area... :cry:
  • sichering Beitrag #4
ALFIrE
fuse 6, 14 nd 38 seem to control the CCM (power widows, central locking,...), but i is only the 14 causing problem...
sichering
sichering - Ähnliche Themen
Engine Smokes and Stutters at 36-56°C when idle, Runs Smooth without Coolant Sensor - Need Help!: Hi everyone I’m having an issue with my 2001 VW Passat B5.5 (96 kW TDI). When the coolant temperature is between 36°C and 56°C, the engine smokes...
passat b8 break lights always on: Good morning, I could use some help from your side. I have a Passat B8, 2018, DSG, 2.0 TDI. Since September I have problems with the car: the...
What Does the Fuel Filter do?: Fuel filters keep particles, water, and impurities out of the fuel and protect the delicate components of the fuel system from wear and tear and...
Do You Know When To Change Tires?: When a car is on the road, the only thing in contact with the ground is the tire. The quality of the car tires directly determines the driving...
How to Wash Your Vehicle Air Conditioners: You may hear the term "air conditioning system flush" when replacing dc air conditioning parts on your vehicle, either as a general industry...
