Diskutiere Digital speed on MFA PLUS im B6 Elektrik & Elektronik Forum im Bereich Passat B6 (Typ 3C / CC); Is it possible to encode an older type of meter that displayed the speed? I'm not sure but I saw somewhere B6 of the function
passat b8 break lights always on: Good morning,
I could use some help from your side.
I have a Passat B8, 2018, DSG, 2.0 TDI. Since September I have problems with the car: the...
Engine Smokes and Stutters at 36-56°C when idle, Runs Smooth without Coolant Sensor - Need Help!: Hi everyone
I’m having an issue with my 2001 VW Passat B5.5 (96 kW TDI). When the coolant temperature is between 36°C and 56°C, the engine smokes...
What Are the Benefits of Using Truck Starter Motor?: When it comes to starting a truck, the starter motor plays a crucial role in ensuring that the engine fires up smoothly. The truck starter motor...
What Does the Fuel Filter do?: Fuel filters keep particles, water, and impurities out of the fuel and protect the delicate components of the fuel system from wear and tear and...
Do You Know When To Change Tires?: When a car is on the road, the only thing in contact with the ground is the tire. The quality of the car tires directly determines the driving...
