3BG Wagon hatch on 3B Wagon... ??
Diskutiere 3BG Wagon hatch on 3B Wagon... ?? im B5 Karosserie Forum im Bereich Passat B5 (Typ 3B / 3BG); :) Hi ! What will I have to do to make a 3BG Variant hatch fit on a 3B Variant ? I'm aware of that the hatch itself is a direct fit, But what...
  • 3BG Wagon hatch on 3B Wagon... ?? Beitrag #1
2stroke
SWEDEN
:) Hi !
But what about the opening mechanism ?
Since the 3BG has an electric activated opening and the 3B is mechanical ?
Have anyone here on the forum done this operation ?
I have read this:
* http://www.passatplus.de/umbauten/heckk ... klappe.htm
* http://www.passatplus.de/umbauten/heckk ... relais.gif
....I have tried to do a Google translation from German to Swedish on the above link,
but that did not help me since I was unable to understand the translation. :( :(
All help are greatly appreciated !
  • 3BG Wagon hatch on 3B Wagon... ?? Beitrag #3
2stroke
SWEDEN
I hope I have a better chance of getting a good response/answer if I write on both Passat Forums.
  • 3BG Wagon hatch on 3B Wagon... ?? Beitrag #4
2stroke
SWEDEN
:? HELP ! :?
I really need some help to understand what I will have to do to get this working.......
3BG Wagon hatch on 3B Wagon... ?? - Ähnliche Themen
passat b8 break lights always on: Good morning, I could use some help from your side. I have a Passat B8, 2018, DSG, 2.0 TDI. Since September I have problems with the car: the...
Engine Smokes and Stutters at 36-56°C when idle, Runs Smooth without Coolant Sensor - Need Help!: Hi everyone I’m having an issue with my 2001 VW Passat B5.5 (96 kW TDI). When the coolant temperature is between 36°C and 56°C, the engine smokes...
Do You Know When To Change Tires?: When a car is on the road, the only thing in contact with the ground is the tire. The quality of the car tires directly determines the driving...
How to Wash Your Vehicle Air Conditioners: You may hear the term "air conditioning system flush" when replacing dc air conditioning parts on your vehicle, either as a general industry...
Ceramic Brakes Pads And Semi-Metallic Brake Pads: If your car is screeching at you every time you pull up to a stoplight or a brake pad warning light is sending you a signal, you can be sure that...
