Interior LED bulbs problem
Diskutiere Interior LED bulbs problem im B5 Elektrik & Elektronik Forum im Bereich Passat B5 (Typ 3B / 3BG); Hi I just replace in my Passat 2004 all bulbs with LED bulbs. There is common problem, when Maxidot turns off, the voltage drops from 12V to 8V...
  • Interior LED bulbs problem Beitrag #1
Kuro
Hi
I just replace in my Passat 2004 all bulbs with LED bulbs. There is common problem, when Maxidot turns off, the voltage drops from 12V to 8V and glow is very low. Obviously car is thinking that all bulbs are damaged and it lower voltage (I think because whenI in this moment replace LED with original bulb, glow is back on maximum intensity on others LED bulbs connected in others lamps.
Any idea how to solve this?
thx
  • Interior LED bulbs problem Beitrag #2
VWFlo
VWFlo
Leonberg BB
HI!
I have the same problem on my passat but also no solution. Maybe it could help to set a resistor between the "light" contacts on one place of the car (maybe front Illumination). This resistor takes a much higher current as the LED lights. Maybe this stabilize the control box and it works like with the "normal" lights. But I don't tried this yet.
I dont know how to calculate all parameters for the resistor...
Another soulution could be, to leave one "Normal" light in one place of the car (maybe in one of the three front illuminations). This has the effect, that the interior illuminatione "Takes" more current and the control box works more or less at the normal way. This works but of course thats not the nice solution...
When I tried it out I'll post it here.
Best regards,
Flo
Interior LED bulbs problem - Ähnliche Themen
Engine Smokes and Stutters at 36-56°C when idle, Runs Smooth without Coolant Sensor - Need Help!: Hi everyone I’m having an issue with my 2001 VW Passat B5.5 (96 kW TDI). When the coolant temperature is between 36°C and 56°C, the engine smokes...
passat b8 break lights always on: Good morning, I could use some help from your side. I have a Passat B8, 2018, DSG, 2.0 TDI. Since September I have problems with the car: the...
What Are the Benefits of Using Truck Starter Motor?: When it comes to starting a truck, the starter motor plays a crucial role in ensuring that the engine fires up smoothly. The truck starter motor...
What Does the Fuel Filter do?: Fuel filters keep particles, water, and impurities out of the fuel and protect the delicate components of the fuel system from wear and tear and...
Ceramic Brakes Pads And Semi-Metallic Brake Pads: If your car is screeching at you every time you pull up to a stoplight or a brake pad warning light is sending you a signal, you can be sure that...
