Why Need To Be Replaced In Time?
Diskutiere Why Need To Be Replaced In Time? im Allgemein Forum im Bereich Allgemeine Themen; 1. Check the engine light The bright orange "Check Engine" indicator light is one of the earliest signs you will notice that the oxygen sensor is...
shindary
shindary
The bright orange "Check Engine" indicator light is one of the earliest signs you will notice that the oxygen sensor is not functioning properly. However, the problem is that this light has multiple meanings. Maybe it's just pointing to the loose fuel tank cap.
Since the reason for this kind of lamp lighting may be ambiguous, it is best to contact a
professional who will study the problem more carefully and determine the root cause.
2. Your engine sounds rough
If you find that your vehicle is not driving properly or the engine sounds unsteady, there may be a problem with the oxygen sensor. When the mixture (oxygen and fuel) in a car is too lean or too rich, the efficiency of the engine will decrease.
Sensor damage can easily destroy certain engine functions, such as engine timing, air-fuel ratio and combustion interval. This is what causes the engine to sound rough or perform abnormally.
3. Increase fuel consumption
As we have already mentioned, when the ratio of fuel to oxygen is too lean or too lean, your engine efficiency will decrease. That will affect fuel consumption. If you find that you are spending more on fuel than usual, it may be that the oxygen sensor is malfunctioning. You may find that the cost gradually increases, because in most cases, the efficiency of the oxygen sensor tends to decrease over time. In fact, to put it plainly, the oxygen sensor is also a consumable of the car. It must be replaced after a certain number of kilometers, which will cause more fuel costs.
08.06.2021
Groesch
1.110
oskar1979
O
987
1.435
SieMone
13
1.132
Greek
Greek
