car bottom annealing oven manufacturers
Diskutiere car bottom annealing oven manufacturers im Passat B6 (Typ 3C / CC) Forum im Bereich Technik; We provide different type of excellent quality hardening Furnaces. It is used for lager parts/machined parts.Also used for repetitive small parts...
haochen
We provide different type of excellent quality hardening Furnaces. It is used for lager parts/machined parts.Also used for repetitive small parts. The use of this treatment will result in an improvement of the mechanical properties, as well as an increase in the level of hardness, producing a tougher, more durable item. Hardened materials are usually tempered or stress relieved to improve their dimensional
stability and toughness. The furnace passed the ISO9001: 2008 quality certification.
Product Introduction
Pit type furnace is cycle type furnace, apply to the pole, long axial parts heat treatment. During the last 10 years, ZHUODA has built far more than 300 hardening furnace running successfully in domestic and abroad, covering Southeast Asia and Middle East Asia market. This impressively proves permanent high quality, reliability and low energy consumption. ZHUODA are expecting become your long-term partner in China.
Available Processes: Available Processes: Quenching, tempering, normalizing, annealing, carburizing, solution treatment, carbonitriding heat treatment.
Protective Gas: According to process requirements
Materials Processed: stainless steel, alloy steel
Parts to be treated: Such as auto parts, shafts, pumps, steel dies, gear, tools (HSS drill bits, milling cutter, broaching tool), rod, long axis mechanical parts.
Heating Mode: Electricity
Product Parameter
ModelRated Power(kw)Rated Voltage(V)Rated Temperature(℃)Effective Size of Charging (mm)
RJ2-25-6253801150φ400*500
RJ2-35-6353801150φ500*650
RJ2-55-6553801150φ700*900
RJ2-60-6603801150φ900*800
RJ2-75-6753801150φ950*1200
RJ2-90-6903801150φ1000*1500
RJ2-105-61053801150φ800*1800
Note: Various size of furnace can be customized as your requirements
Product Features
1)Cast fan for uniformity of temperature and atmosphere.
2)Electric furnace more area and control, further improve the uniformity of furnace temperature.
3)Adopts energy-saving lining, reduce the production cost.
4)Low installation and operation cost.
5)Good and repeatable result of the process
Production Details
Application
Manufacture Processcar bottom annealing oven manufacturers
website:China Car Bottom Annealing Furnace Suppliers and Manufacturers - Zhuoda Furnace
08.11.2018
640
haochen
2.333
2.183
1.222
DasJoghurt
37
5.478
ICeY
